2.9 Problems?
Scat
Okay it's a 1988 2.9 I have spark, no fuel, i spray fuel in the tb and it runs fine it has new relays both of them on the passenger fender, and inertia switch , I have 12.5 volts at the injectors no power at the fuel pump, I straight wired it ( temporally) it works no air in the system, but it will not run ( been sitting for 5 yrs) also checked the grounds good so far , one thing though I have 12 volts at the inertia switch, well when it's open when I reset it it drops to like one volt. Any ideas where to go from here
the harness's on these like to rot out. I bought my truck after it sat for years and got no juice the the FP. Got undernethe (Actually cut a hole in the cab above fuel pump)-inspected the wires and sure enough the ground wire was corroded away to nothing.
I'll check the wiring some more, does the wiring harness supply to both fuel pumps? Thanks,
Is there any aftermarket parts for the 2.9 to make it carburetored and to switch it to a points distributor?
