2.9 performance cam?
rangerdude91
virginia
has anybody been able to find a mild cam for one of these motors? or are the any other alternatives for a bigger cam for the 2.9. i have been looking every where and cant find one. im rebuilding my B2 motor and just want a little more power, already got new heads, pacesetter headers, and im about to order a engine rebuild kit but i want to see if there is a better cam
thanks guys
NW
back in the days when I was younger and 1960 cars were brand new: Isky cams in Culver city CA would regrind your old cam to like new condition or any grind you wanted as long as you knew what lift and duration you needed.. I know I can still do it on my airplane.
Have you tried Summit?
ive had no luck with them, jegs, or anyone on the internet yet
NW
Cam profiles should match what you're using the truck for, don't buy it because you think the numbers look good... A cam grinder will help you in getting the right cam for your application. Just need to ask around, just because they don't list it doesn't mean they can't do it. It's going to move your power band, and you want to make sure it's making power where you need it to.
