CMFG43
- Sep 27, 2014
- Automatic
hey all, this is my first time posting here so im sure i should spend a little time going through the discussion boards, but im in a little bit of a rush and hopefully someone can help. i just got done doing the headgaskets on my 1989 2.9 ranger, got the timing set and the truck started right up, after identifying it had a coolant leak at the upper radiator hose and a vacuum leak that i quickly repaired i tried to start it again and no luck, it cranks just fine, there is good fuel pressure (enough to erupt out of the schrader valve on the fuel rail when pressed) but absolutely no spark, checked out the coil with a multimeter and its got 12volts at the coil and the other end of the wire at the distributor so theres power there. ive heard the ignition control module is probably to blame and thats my next stop. im just curious if there is anything else that could be causing this. ive been a jeep guy for years and this sort of sounds like a bad crank position sensor in a 4.0 jeep motor to me, but as far as ive been able to figure out there is no dedicated crank position sensor in a 2.9 and it all works through the ignition module and within the distributor. any help would be great. also if it helps anyone to identify the problem, the truck ran great before the head gasket change, i drove it daily and aside from using a little oil it never let me down. thanks in advance.
