2.9 no power
It's on the passenger side inner fender - pretty close to the firewall.
It is mounted on the inside of the pass. fender near the hood hinge. Both of the connectors ( 6 pin and sti ) are plugged into a plastic connector/holder, just unplug the 2 test plugs from the holder and your good to go. Good luck and let us know how it goes.
would this work for the Analog Voltmeter Method
[/IMG]
this is what the ends look like on it
[/IMG]
yeah, thats exactly what you need. use the two cords that react when you touch the positive and negative terminal on your battery. Then, you should be ready to test.
got it fixed it was a bad fuel injection i hade a set out of a parts motor and cleaned them up good and it runs like a champ now:yahoo:
