2.9 motor pull
Broncopower33
Ramona, Ca
Has everyone pull motor leaving the tranny connected, and if so was there enough room? My problem is my motor is siezed so I have no way of un-bolting the flywheel. Was just curious if both could be pulled.
It can be done. I pulled mine with trany and transfer case all attached. it is tight pull
ummmmmm..........What? how does that stop you from unbolting the flywheel???
not trying to be a dick but, wouldnt that help?
The trans to engine is only like 6 bolts, i just think it would be harder to pull both then just the engine......
