freerider6_9
- Mar 3, 2008
Hey guys, havent been on here for quite some time as i retired the ol B2 for a while but i pulled it back out now for some fun. It ran great when i pulled it out and never missed a beat while it was cooler spring weather, well anyways ill give you some back ground info on the truck... it is an 86 bronco 2 2.9,for now, the truck ran great as earlier posted and then when the temps started getting hotter everything went way down the drain.. first it was the fan, but thats a long story in itself and its now electric. i will stop listing problems now as they dont really relate to my issues.
Ok when i first pulled it out it idled rough and high, so i cleaned the iac and sea foamed it, all was good for a while, i scanned it and got a code-18>no tach signal, so i changed the tfi and all was good and clear on the scan tool(not cheap wall mart type, profesional scan tool from the shop) and it ran GREAT...till this issue
ok here is my current issue. The truck runs great when its cooler out or when i first run it but when it runs for about an hour and temps under the hood start to rise the truck will start to stumble on acceleration and idle really rich. if i feather the throttle i can save it most of the time. if i push in the clutch(standard) and rev it it takes a few seconds but it smoths out and revs fine, its only when there is a load on it. \also when this is happening if i floor it it sounds like its missing either spark or fuel
I have tested vaccum and its a steady 14-16 needle sweep and very consistant so thats good, also no fuel in fpr
Well as i dont have alot of spare time i am hoping some of you can help me and save me some testing, sorry this post is so long too. Thank you all in advance as you havent let me down yet.
If anymore info is needed just ask
