2.9 hard to start after warm up
wigwag
hey guys I have an 86 ranger 2.9 that will start up fine when cold and run fine but after warm up like driveing to the store and shuting it off it will not crank. But after you let it sit for an hr or so it will crank up just fine i am about to loose my mind I have replaced every sensor except the o2 could this be my problem?
Leaking injectors can flood you out on short trips, but the fuel evaporates when sitting for longer periods. Check you fuel pressure after you shut it off, it should hold constant.
thanks I will try that and let you know what happens
