2.9 ECT Sensor simple fix!
ProjectMiniBeast
Firefighter
EMT / Paramedic
United States Of America
2.9 V6
2"
31x10.5r15
I have recently had some issues out of my 1991 2.9 auto Ranger STX 4x4.
The truck when cold couldn't keep a good idle. It would drop to ~500 RPM and die at times if you didn't keep the throttle pressed.
I hooked my code reader to the truck and got Code 51. This means the Engine Coolant Temperature Sensor (ECT) is out of range.
I knew the sensor shouldn't be bad because I replaced it just a few months ago. So I unplugged it to look at the connections.
Turns out that the female end of one of the pins was pushed back into the plastic harness, causing it to not make a good connection. I fixed this with some needle nose pliars and plugged it back in.
After running the codes again, Code 51 no longer comes up! Just thought I would post this for anyone who might be having the same issue. Make sure and check the connection first!
Sent from my SM-J337V using Tapatalk
thank you! same think happened to mine but i can’t figure out how to keep the pin from pushing back
Can you post a clear picture of the connector?
