wisconsinjimmy
- Oct 19, 2008
Help, I have been chasing this nitemare for a week now and have or seem to have done all the teast I can. When I turn on the key there is no fuel pump sound (pump is OK) if I jumper the module it will pump, also have 12v to the coil and did test the TFI which told me that the TFI was bad so I put in a TFI from a running Ranger still no spark or fuel pump and I have tested the inertia switch and it is operating normal. Could the ECM be the problem? I would think the truck would still run albeit poor if the ECM went out.
