2.9 b2 coffee table?
Similarly I have an old 2.8 crankshaft and flex plate that doubles as an ashtray in my shop.
ahhhhhh yes.....pj will be proud
When I pull the engine out of my sons bronco 2 I am entertaining the idea of dismantling it and making it into a coffee table! Little heavy yes, but it’ll be in the man cave so it’ll be on casters.
Use a 3.0 instead....itll be a better use then what they are typically used for.
No matter how clean you get it, it will still find a way to leak oil and antifreeze. It’s a 2.9L, that’s just what they do.
Yet youll still get 300,000 sips from it
Sounds like the perfect use for a 2.9! You might even want to put some resin puddles under it that look like oil and antifreeze!
2.9's might leak, crack heads, tick, and be quirky as hell but...
Ill pull 2 plug wires and stick duct tape over half my TB and still smoke a vulcan.
What do you think @PetroleumJunkie412 ?
