matt jak
- Feb 10, 2010
so it was running very poorly i replaced spark plugs and found out it was only running on 4 cylinders , the new plugs and wires made a huge diffrence,i also replaced the cap and rotor, about two weeks later it started stalling out once the engine is hot and now wont fire at all , my coil is good but theres no spark when i test it, so i have a another ingnition control module which i just plugged in to see if it would work, but it made no diffrece?does it have to be bolted to the dizzy in order to ground?any suggestions?
