2.8 rear main oil seal replacement?
That is another animal you might be able to raise the engine enough to pull the pan and rear main cap and put a two piece seal in or drop the front end but however you do it put a new high volume oil pump in it. are you sure it is the rear main did you have a new O ring on the dizzy when you put it in. was it real tight to install it
Howdy 84. You are aware of a failing pcv causing excessive pressure in the crankcase and PUSHING oil out the rear seal...aren't you? I always replace the pcv before thinking of working on that seal. In the event of a little too much blowby I have hooked the valve cover directly to vacuum without a pcv and had good luck with the oil leak.
Big JIm
thanks im just trying to figure out where to hook my pcv valve up at. my motocraft 2100 didnt have a spot at the base like the old feed back one. any tips on where to hook it up?
Yep! Anywhere you can cut a vac hose and put a "T" in will be ok! In particular one on the carb is best but anywhere will work.
Big JIm
the rear main is still leaking after i replaced the pcv. so i m running some bars leak to see if that helps. if not i have a friend to help me replace it.
The rear main seal on my 1983 2.8 is a one piece unit and you must remove the tranny, clutch and flywheel to get to it. I would presume all Ranger 2.8's are the same. Notice, I did say "presume". But mine is difinitely one piece.
Eric
I wasn`t sure wether there was a two piece seal. I had a dodge 360 and put a two piece seal in but the parts guy gave me a ford 360 seal it seemed to fit ok not knowing and when I started it it made a spinning noise and proceeded to drain the pan on the garage floor of my brothers new house his wife was pissed.
