scoyote
- Oct 29, 2009
Looked at a Ranger that the mechanical owner had swapped out a great 2.8 into an 84 replacing the 4 banger. He didn't prudently check out things -just swapped the computer and necessary harness bits--and droppped it in. Then found no oil pressure! Thought something wasn't right with the sender--this is crazy---so put a guage on it and you guessed it--no oil pressure. What could have happened here on an out and in swap. I don't think you can get clearance to remove the pan and check --maybe reach in and drop the pump inside might get it?-I know this will have to come out again--just wondering if anyone has any ideas what might have happened---tube drop off??---scoyote
