Roadhog
iam installing a low milage used engine in my b-2. before i install it iam replacing all the gaskets. now that the oil pan is off is a hv oil pump worth the $75 bucks or is it a waste of $. i had a hv oil pump in a race car i had with a 2.3 ford engine in it. i finally had to drill out the distributor drive gear roll pin hole,modifiy a grade 8 allen head bolt, and install it as to not shear the gear pin. has any 2.8 hv pump users had a problem like that.
