Yes. Ford makes two tools that make it very easy after you get the dampener off- and they make tools for removing and replacing that, too. One tool has 'threads' that dig into the old seal, and the other tool seats the seal just right. (Check e-bay; the tools ar4e getting cheaper as these engines age)
I never tried it with make-shift tools, but it might be done.
I just used a damper puller and two sheet metal screws. Pull the crank pully and screw the seal in about three threads and carefully pry side to side out with a pair of vise grips. The slowly tap the new seal in being careful not to bend the seal I use the back of a large socket on the seal until it is good and flush all the way around.
Look close at the seal surface on the pully if it has a deep groove in it dont press the new seal all the way in, leave it out about 1/32 of an inch and good and square and clean the seal surface of the pully good with steel wool and 400 grit emery cloth.
Don't use a Timken it won't fit. It slides right inside the cover. Rock auto or CarQuest sells a National brand.
Timken OD 2.176
Shaft 1.693
National OD 2.211
Shaft 1.654
Jim
For
