drgrcr
- Oct 15, 2011
- Automatic
A little over a year of gathering parts of ebay the engine in the Ranger is getting rebuilt. It was in fair shape, the bore was straight enough that it could have been honed and a rering would have put it back in shape. But....I wanted a little more spunk. So here is what it is getting,
.030 over bore
Decked the block to get the clearance .040
Cylinder heads, Found a set of 78 Mustang II heads (non exhaust cross over heads) moderate porting, larger 2.9 valves, milled too 38 cc's, added cooling holes for improved exhaust valve cooling.
New stock camshaft and lifters
Ported intake manifold
Took the engine apart and checked the cylinder head cc volume found 44 cc's that with .040 deck clearance, .050 head gasket thickness equated to 8 to 1 compression. New compression will be 9.5 to 1.
Replacement Speed Pro piston were .050 shorter than the original removed pistons, so when the block was bored I had the block decked .060, when the pistons were installed and the deck height checked again, it was found at .040...should have been .030. Be a little short of what I was wanting for the static compression ratio but I am mostly looking for improved fuel economy with a little upper rpm hp improvement.
I was concerned that after milling the block and manifold that I would have a drastic intake port misalignment, I had an old manifold that i cut the top part of the port off so I could see how bad the ports were mismatched, to my surprise every thing matched up. great!
If everything keeps going like it has been should have it back in the truck before Christmas. Stay tuned...
.030 over bore
