2.8 auto to standard swap
golfbuddah
I have a low mileage 1978 2.8 v6 with c4 tranny from a mustang ll.
i would like to put a 4 or 5 speed in it. i need your help to steer me in the right direction. rear wheel drive application. thanks
The 2.8 is not a power house so you would be best served with the five speed. Maybe a tranny out of a mid to late 80s 2.9 would work. The rear tranny crossmember/mount could be a challenge but the tranny should bolt right up?
I have tried them but they tell me to convert to a t5. the bell housing to put onto my 2.8 seems to be the issue. does anyone know the engine weight difference between my 2.8 and a small block v8?
I recently did this to my 2.8 over last summer. I put a M50D in replace of the slow C3. It bolted right up with just a little trans tunnel trimming in the front (keep the M50D trans bell housing bolts though). Save your old trans mount and everything will bolt up perfectly to the original cross member after drilling some new holes for it to mount to the chassis. I used a '84 clutch master with a pad from a '92 4.0 engine. All of the rest of the clutch parts were for a '92 ranger (very important!). If you get stuff from a later model, your master and pad won't work. If I can remember correctly, I got a driveshaft from and extended cab longbed ranger. If need be, I can measure it for you. I skipped all of the clutch switch things when putting in the new pedal assembly. Saved time and it will be more reliable in the future.
Feel free to ask away if you have any other Q's!
EDIT: Pay attention to the quick release fittings on the throwout bearing and clutch line. They need to be the same color to hook up (mine are both black).
