fireguy12117
has anyone had EGR insufficient flow codes and had success solving the issue?
I've been fighting this sumbitch for months now and had no luck whats-so-ever.
Replaced EGR tube since it cracked and failed near a DFPE senor pickup tube.
new EGR vacuum soleniod
new DFPE sensor
new vacuum like to the EGR valve
the only thing i can think of now is replacing the vacuum line to the solenoid even though it tests good, and checking to make sure the DFPE sensor hoses are in the correct order.
this has been a weird series of failures that occurred over a very long time now. i shotgunned a vacuum solenoid with shody troubleshooting which ended up really being a bad DFPE sensor, which worked for 6-8 months. then found a cracked tube, fixed it, now i cant get anywhere with it.
im just hopeing i overlooked the obvious simple thing here since all the big stuffs been eliminated. oh, EGR valve works, put vacuum on it and it opens and closes find...and the TB port is clear as well.
new DFPE sensor
