Most Ford engines before the Modular family run main/rod bearing clearances around .0008"-.0015". On a performance build for the street, the loose end of that specification is better.
Note, end play is the term for the forward/aft clearance of the crankshaft. That spec is .003"-.008". The above specs are 'bearing clearance'.
For
