2.3t BUILD#2
gabes2.3project
Greater Boston Area
So I've decided to reclaim the previous glory that i once knew being the only person that i know of in MA with a Turbo Ranger.
what i have
-1992 4.0 2wd ald4 with a 3.08:1 (only needs rear cab mount brackets :}
-My entire other project 1990 2wd stick with the 88 2.3 complete still runs after smashing :|
I wanted to try the auto for a bit since what i hear the 4.0 version for this year is a bit tougher than previous ones, so i found a bell housing for the 2.3 with a pump. I will have to find a flex plate, torque converter, and shim.
Other than computer, repin, and messing with the DIS wiring to mate with the TFI Should i have any other concerns?
just some tear down progress
more to come
What is up with the rubber piece on the front of the turbo? It looks like it's stretched WAY too much to create a good seal.
Also, the bracket for power steering and the alternator, is that from the Thunderbird as well? I did the turbo swap, but I kept the alternator on the passenger side of the engine. Now that I see how open this makes the engine compartment, I'm going to find that same bracket.
bell housing
bell housing came in yesterday, i believe i got a park pawl with the bag of hardware, i'll cross that bridge when i get there, pump gears look in good shape but according to the A4LD service guide the larger gear was backwards, im gonna find a good trans shop to have it re aligned.
lost a little weight
frame, twist and crunch
engine inspection
This morning I decided to start going through the engine to see what could be repaired while waiting for the warmer weather. Another ps bracket, engine mount, dizzy cap which I am super amped broke other wise the engine would have lost all its oil becuase the filter busted open when the engine mount tore through. Also discovered a leak I wasnt aware of before and need a suggestion, looks like a lower intake gasket just under the coolant port the gasket has turned into a thick sticky substance and on cylnder 4 oil is present on both manifold and gasket allowing a sepage to look like an external HG. And here are some pics
One last thing I took a picture of the part # of the bracket I use for the ALT
pics
here we are
So after looking deeper its time for the head gasket, decided to take the exhuast manifold off and one of the bolts snapped, damn. Tried to drill it out and my carbide bit snapped 3/4 of the way in, and attempted to drill it out but it was not having it. So I have the ol 90 head and planning on using that one I still have all the accessories to run it. Other than that we're looking good, :icon_thumby:
I think the engine bay looks so open because the parts that define the edges of the engine bay are gone.:icon_rofl:
I've been using and abusing an alternator/PS mount like that for several years (IE no support bar to the intake like it's supposed to have) and haven't had any issues...
If you use the '90 head, you'll have to switch to distributorless ignition as the intake will interfere with the distributor... the wiring changes are easy (I just wish I remembered what I figured out needed to be done to keep the tach working) as the stock Ranger harness can be used completely with just adding the turbo specific sensors and moving a few wires at the computer... making the crank sensor from the '90 fit on the older engine is easy too if you make a template off of the '90 engine and drill the 3 holes for the crank sensor, for the locating pin tap it to 6mm and use a 6mm bolt with a shank and cut it off, that's what I did and it works great. For the front seal housing, the one from the '90 needs to be used, and it lines up just fine except for one bolt is a little bit off, you can slot that hole in the cover.
Yeah, I suspected that would have something to do with my thought. :icon_thumby:
However, when I install my front mount intercooler, I'll put the alternator on the driver's side with that bracket so that I will have more room for piping between turbo and throttle body.
thanks for the imput scotts90. So the more i think about the head swap the more i would like to keep things simple, I'm going to try to save the 88 head and have a worked up a little plan on doing so. I'm using the 90 ex manifold as a guide I'm gonna go in and grind that non ferrous * * out of there with a carbide bur grinder. Once its out and clean i'll tap new threads and clean up the rest on the head and get new bolts. By the way does anyone know what the exhaust manifold bolts are made of on these engines?, i have to drill quite slowly with moderate pressure other wise it has nearly no effect with the carbide drill set i have.
The bolts are probably just a decent grade (8 or higher)
Are you using a left handed drill? That helps a lot, sometimes you get lucky and the remaining bolt will start to twist out with the drill.
i'll keep an eye out for left hand cutting bits next time i need a set thanks man never would have thought to try it, the drill i have can be used for either
People keep saying they want to keep a distributor for simplicity, I kept the DIS for simplicity... If I was going to do it again with what I know now I would have done things differently and swapped more parts between the DIS and older engine, but back when I did the swap I was intimidated by going internal...
The manifold bolts should be grade 5, but after that long are probably heat cycled to be fairly hard...
