- Jun 2, 2010
- Automatic
I got a 1986 ford ranger 2.3l manuel.My problem is it will not run it sill crank but not run or even try to run.It has a yellow/reddish spark at all 4 plugs and has 40psi of gas pressure.So far i have replace the coil,dizzy cap spark plug spark plug wires,new dizzy,new rotor button,and its in time and on the compression stroke with the rotor button pointing to number one on the cap.What should i check next?
