2.3L thermostat housing - use gasket + sealant, or just gasket?
bbb0777
On the 2.3L thermostat housing - should I use the gasket alone to seal it to the engine, or the gasket + RTV silicone material?
I have several proper gaskets, plus the RTV silicone material already. Just not sure whether to use the RTV too is advisable or not. Thanks,
After a near miss with blue RTV, I went back to Aviation Forma- Gasket #2 goop. I use it wherever steel aluminum and coolant are present.Put down a coat, let it skim over. Put the gasket on I also goop the bolts and the holes. It isn't for leaks, it prevents the bond from dis-similar metals. Some engines waterpump bolts go into the water jackets. Itsa Jeep thing, we wouldn't understand. :D
I like permatex #2 on the gasket and anti-seize on the bolts.
You should probably use the gasket and RTV just to be safe. Blue RTV worked perfectly for me.
weather strip cement on housing then stick gasket to it . DON'T PUT WEATHER STRIP CEMENT ON BLOCK YOU WILL HAVE A HARD TIME CLEANING BLOCK NEXT TIME....
I've always just used the gasket and blue rtv. Never had a problem leaking or cleaning it off my 2.3. Done it 4 times now.
Like he said...works every time.
