- Aug 7, 2007
- Michigan
- My credo
- If you're not making mistakes, you're not learning.
I've read through the thing in the tech library but still had an issue.
The adapter pictured looks EXACTLY like the one I pulled off my 2.8L, except that the hollow bolt is too short to fit in the existing threaded hole in the block. the bolt looks the same length in the picture too. is there a longer bolt I need or some other piece? I never actually unscrewed the original hollow rod, but held it up right next to it and I doubt it would reach at all. I even poked around in the blocks opening and the hollow threaded rod indeed goes back a ways. anything I can do or am I doomed to have a sideways filter?
The patient is a '97 2.3L 2wd manual, std. cab short bed.
