- Jun 1, 2013
- under my truck
- Manual
Hello, I have a 1988 ford ranger xlt that I'm putting back together. I've heard that the injection systems on the newer 2.3s are more efficient, since the older system (like the one on my motor) use batch fire
while the 2.3s in the fox body mustangs have true multiport injection. The only problem is the fact that the 2.3 in the mustang had distributorless ignition and dual spark plugs, so I have no idea on how to merge the 2 systems together. I want to keep the head I have now, and just change the ECU and do some rewiring. Has anyone done this before, since I could use some advice on what parts I will need, and any pitfalls I might run into. Thanks.
and the mass flow/DIS version has 105 HP. If I am not mistaken this is due to the better flowing head. I think the work and money is worth more mpg and HP, since I need to take the motor apart anyway to do some seal replacement. I was going to replace the valve guide seals and the cam seal but since I am going to be in the general vicinity I might as well put the better flowing head on. So what I am asking for is a write-up on how to convert it over from speed density/single plug to mass flow/DIS. I know it's possible but I want to know about the details too. Thanks
