well ive bought a new truck, it dont run as good as i like
specs:
87 2.3l 5spd, no ps/brake booster, just an alternator
back story: bought this truck off craigslist for 800, body is mint, motor seems solid(no oil leak/blow by/smoke) old owner used it to comute from school and back, nothing abusive. he said he changed fuel pumps, spark plugs and spark plug wires. it drove for a few miles with constant dieing and eventually it got chained to another truck and towed the rest the way. old batt was deadish, one cell was shot in it, so i got a new batt, ALT is good, 14.2 volts when running. managed to drive it 1 mile to my house after a new batt.
here the symptoms:
-tends to stall after 20 secs of starting the engine and letting it idle.
-stalls when pressing the clutch in to shift gears(due to letting off the gas)
-motor bogs down and stalls if throttle is held in at same place over time, did not try WOT as its an old motor.
-can be kept alive by backing of the throttle for a sec and then going back on it, and then letting off again.
-noticable smell of unburnt fuel in the air.
what ive done so far:
-cleaned IAC valve with TB cleaner, was full of carbon, plenty clean now, it dosen't solve the stalling issue tho.
-removed the air filter, it was dirty and i cant get a ride into town yet, it didn't help so i put it back
-checked the fuel pressure regulator for leaks, no fuel in the vacuum line, nor dose gas squirt out when its primmed, so FPR is not leaking, not sure if its 100% good tho.
-checked for loose vacuum lines, i dont think i got them all... i think i need to go find some chewing gum...
-gave the cat a tap to see if it rattles, no rattle, exhaust gases seem to come out of it ok when its running.
things i noticed:
-no black smoke
-pulled a plug, not covered in black soot or looks burned, seems healthy, altho its a new plug from what im told.
-vacuum seems weak, pulled the vac line going to the PCV, motor about died when i took it off, didn't die when i stuck my finger over the end of the line, well it died a few secs later, no noticable suction with my finger on it while running.
things i may wana check:
-O2 sensors? suspicious because motor dies around 20 secs after a cold start, about the time the ECU would check the O2 sensor.
-fuel quality, i have no clue as to what condition the gas in the tank is in, except i have a half tank of it from the old owner... it should probly be OK.
-leaky injector? giving out to much fuel flooding out the engine and leaving the fuel smell in the air?
-bad EGR valve?
guys help me out here, this is the first car i ever bought and named...
EFI is like dark voodoo magic to me, to many danm sensors. i realy wish i found a pinto 2.3 intake+carb right now
on another side note, i moved here not to long ago and have a very pathetic set of tools wich include channel locks, vise grips, a set of metric/us wrenches abd socket set without exstentions, some pliers, various screwdrivers, a hammer, a multi meter, WD-40 and off course, duct tape... dont got much of a budget so i wana do alot of testing before i shell up the dough for a part, even if i have to bypass somewat important things to verify.
specs:
here the symptoms:
things i noticed:
-no black smoke
-bad EGR valve?
