2.3 valve sizes
Ggreen21
I run a mini stock car out at Irwindale speedway, which we are required to run stock valve sizes. I currently have two different heads, an oval port and a D port. I would like to know the stock valve diameters for them, if they are the same or one head came with larger valves from the factory.
All 2.3 heads to my knowledge had the same valve size. I can't remember the exact size, but most head shops can tell you, ill go check bo-ports site and update it.
And just fyi, oversize valves don't really help a stock head, we can't port them enough to make use of bigger valves.
