2.3 Tranny swap.
v8steel
Here goes... I've searched for this and can't find a clear answer.
I can buy a 1992 ranger with a 2.3 and 5-speed, but there's a problem with the 5-speed.
No matter where you move the shifter, it's stuck in some forward gear. I don't know which gear. I can press the clutch and start the truck, so the clutch seem to be dis-engaging like it should.
If I decide to take a chance and buy this truck, any ideas where I should start looking for the tranny problem? and...
What other engines shared the bell housing bolt pattern of the 2.3 should I decide to look for a replacement trans?
There's also an 86 Ranger with the 2.9 and 5-speed. Do they share the same bell housing pattern?
Any help appreciated. Thanks!
no the 2.0/2.3/2.5 lima engines have there own bell pattern
I do not know if the bell umbolts from the gear box of the 2.9 and will take the 2.3 bell
Assuming that your truck is 2wd, the following transmissions will fit according to my salvage interchange.
MAZDA B-2300 1994-97 M.T.; 4x2
RANGER 1988-89 M.T.; 4x2, 4 cyl
RANGER 1990-97 M.T.; 4x2, 4-140 (2.3L)
