Would it be possible to swap to a 2.3 ecoboost with a 6 speed manual from a 2.3 engine with a 5 speed manual
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
2wd or 4wd?Would it be possible to swap to a 2.3 ecoboost with a 6 speed manual from a 2.3 engine with a 5 speed manual
2wd or 4wd?
[/QU2OTE] 2wd
The only reasonable way I see to do this swap is with the Duratec transmission and Ford's $2000 wiring harness/computer. I wish there was a better way...Possible, absolutely. And other ecobost swaps have been done. But its not really practical and would be VERY expensive. If you have a 2.3 duratec you have the same bell housing pattern going for you, if its the older lima they do not match.
You would essentially need an entire ecoboost vehicle for the swap. Then you run into issues like the 7.5" rear end being a bit weak for an ecoboost, the heater box not having room for the turbo, trying to figure out the cluster, if its post 2004 that means beating the security system, and many other hidden challenges.
No version of ms has drivers for gdi injectors. I am not sure the fuel timing accuracy (and modes) are capable of running gdi well even if you can get them firing.
