2.3L ('83-'97) 2.3 liter 5 speed pilot bearing
ccaissie
5+ Year Member
Engine swap from my sweet running, rusted out Donor '93 Splash 2.3 liter with 140k....... into a Roadworthy '93 XL 2.3l. that blew a head gasket at 180k. Doing seals, timing belt, clutch, flywheel, ring gear and all that during the swap
When swapping clutch and transmission, I see the Donor 2.3 has a bad pilot bearing in the crank. There's a shell, but no needles . The junker engine from the XL had a complete needle bearing in its crank.
I tried some improvised pullers but couldn't get the remnant bearing shell out of the new engine. ANY HINTS?
I might further try if I can get the needle bearing out of the junker, but why? practice?
I could quick heat it with a torch to expand it then let it cool. Not worried about the rear seal...that's being replaced.
Pack the hole full of grease. Then tap a dowel that barely fits inside the bearing shell. The shell will come out as the dowel goes in.... Magic!
If there's no rollers that probably won't work, I've had to extract a couple like that over the years and ended up with a dremel with a small diameter stone and ground a line to weaken it then broke it out with a screwdriver or whatever...
As clever as the dowel piston hydraulic idea is, it didn't work. I too used a carbide burr and thinned it to where I could chisel it out.
Great minds think alike, eh?
The corollary ;
Fools seldom differ.
But not in this case.
Good job!
