2.3 Lima or 2.3 Duratec??
hilltopfarm
NW WA
OK, I am looking at buying a 2.3l ranger. There are two I am going to try and test drive tomorrow. One is a 01' 2.3 Lima, the other a 02' Duratec.
The Duratec has 92K on it for $5800, the Lima has 67K on it for $7999. Have any of you guys found one engine preferable over the other? Is the Lima more reliable than the Duratec? I need the truck for commuting on the highway to my 12 hr work shift, so I need it to be reliable. Any suggestions???
Thanks!
I know that 2.3 Duratec is tough motor, but it like lots of RPM's to get good MPG.
we have one at the company i work for it been ran out of oil 3 or 4 time it has 180k and its still ticking. The intake does have a internal butterfly, the shaft wears thought the plastic intake. thy cost about $275.
The 2.3/2.5 has a lot more low end torque and tends to get 28mpg freeway.
I think its a tougher motor, but you do need to deal with the timing belts.
2.3/2.5 can last along time i have seen quite a few having over 200k on them.
I hope that helps
I hope that helps
Thanks, is the 2.3/2.5 you are referring to the LIMA engine? If so then the Lima is diffidently a better motor. I guess the timing belts go out on it often??
I'd say they're roughly equal in durability/reliability. A 2001 Lima would be a 2.5, not 2.3. Timing belts don't go out often, you just need to replace them around 100k miles. It's a non-interference engine, so you won't damage anything if it breaks.
Yep, that's a Duratec.
"2.3 DOHC"
Limas are 2V, SOHC while the Duratec is a 4V DOHC.
So a 01' 2.3 would be a... Duratec???:icon_confused: Here is the listing http://www.sabetimotors.com/en_us/unitDetail.asp?Unit=400123
today's your lucky day....I am going to save you from making a mistake.........both trucks and engine are good.....the duratec has more power........but that truck is grossly overpriced.........why are you buying form a dealer? is he financing the entire thing? you can look on CL for a few weeks and find plenty of trucks..I would be glad to give you any assistance you need from the east coast......
*I busted out laughing when I saw the "special".....he lowered the price $49....:icon_rofl:
Lima's are twin plug engines, meaning they use 8 spark plugs instead of just 4. The drivers side plugs, although not necessary to run, are a big pain to replace.
I guess 8 spark plugs are better than 4?
Not really. The extra four go off on the exhaust stroke primarily for emissions purposes. Really, I wish that there were only four on my engine.
Yes the 2.3/2.5 is a LIMA I think 98 was the first year thy used the 2.5 version
Sent from my myTouch_4G_Slide using Tapatalk 2
Yep the 2.5 started in 1998 when the new generation came out. It was used until halfway through 2001, which is why you see Duratec and Lima 2001 Rangers.
