acidh3r3t1c
- Aug 11, 2007
- Age
- 35
- Des Moines Iowa
Okay i know this doesn't fit the best but i know its a similar engine to the rangers so i was wondering if you might know what the problem is. I've got an 87 2.3L mustang and it just started knocking pretty loud there wasn't any build up it just started on the interstate. I limped it home and have tried a few diagnostic things. I was concerned about it being a rod bearing and i had heard if i pulled spark plug by plug it would quiet it down a little when i got to the cylinder it was bad on. It didn't change at all as i went through all of the plugs so im hoping its not that. What im thinking it is, is the hydraulic lifter w/ the lash adjuster i've heard these aren't the most difficult to replace and i have them on order. I plan on replacing these unless anyone has any other ideas of what the problem could be and how to diagnose it.
