kimcrwbr1
you can test the pickup coil in the distributor but does sound like that could be the problem did you verify a good ground to the distributor base to the ground pin on the TFI while it is together
when you have the dizzy cap off.. reach down and try to twist the rotor, it should only move about 1/8 inch, more than that and I would say the teeth on the dizzy and the aux shaft ahve wore and fail.... This has happened to me several times..
if it passes the twist test, spin the engine over on the key and see if the rotor moves smoothly.
