Loanranger
- Aug 6, 2007
- Age
- 44
- Puyallup, Wa
1972
I'm getting close to needing an engine in the Fordzuki, and I've got a donor for it, a 97 Mazda with the 8 spark plug 2.3, with a m50d five speed behind it. The problem is, the trans won't fit in the zook, because it's longer than the tk4 that's in it now, and there is no room to reconfigure.
So basically the question is, can I use the tk4 that's on the '78 2.3 on the '97 2.3? Is the flywheel the same? Ie, can I just bolt a
new tk4 clutch to the '97 2.3 flywheel? I assume the bellhousing pattern is the same. Anything I'm not thinking of?
Edit: Maybe this should have been in the trans section, but it's a 2.3 swap, that's why I put it here.
