Peregrine
I have a 2.0L carbed 1987. From the oil fill cap, there is a hose which leads to the air cleaner and the hose *should* connect to something on the air cleaner. The problem is, when I got the ranger, whatever it connected to was broken/removed so there is a hole on the side of the air cleaner for that connection point and the oil filler cap's hose was doubled over and crimped closed with a piece of wire. I purchased a new cap with hose and then have the hose poking into the side of the air cleaner housing through that hole and forgot about that until recently when the oil buildup has been enough to start leaking down around where the bimetal sensor connects to the housing and was able to get some spots of oil ont he driveway.
My question is, what is that bloody sensor named and where can I find it. I've looked through my haynes manuals to no success and have browsed napa and autozone and a few other online parts places looking to see if I could figure out what I am missing to no luck. None of the wrecking yards locally that have any of the 1st gen rangers have any with engines in em still, let alone have any with the carbed version. I seem to remember on an older escort I had many many years back that there was a little plastic housing with a kind of crescent shaped filter that sat on the side of the air cleaner, but again, I have no clue what the name might be nor where to find it. Can anyone help?
