I am trying to find out if a intake from a carbed 2.3L will fit a2.0L or maybe even a head swap to try to get just a bit more power. Every engine swap candidate I have found is injected.
2.3 head wont work on a 2.0 ( valve size to bore clearance). However you can run a 2.0 head on a 2.3 but it wont flow as good without major port work. Other then that its mostly just the block & pistons that are different between the two. Almost everything else interchanges.
For
