anyone know where i can buy one of these from ?? are they the the same as the 2.3 unit ??
the 4 wire ones have pumps on them, there used on the EFI rangers, IIRC 85 was when the 2.3 was switched to EFI so mabey a 83-84 2.3 can work. EFI pumps put out too much PSI for the carburator on a 2.0. those 2 wires im guessing are for your fuel float, it controls your gas gage.
ah, so you just need to make your gas gauge work...
If it makes you feel better, my gas gauge works but not properly...it sorta bounces between full, when there is enough gas, to about an eighth of a tank where it starts reading normally...there are levels in between but they vary depending on hill grades and what way the truck faces the hill...I like to park it with the nose in the air so I always get a surprise when the gauge rises after the truck levels out...
