2.0 motor mounts
tonfro
Hello
New to this site, but have read just about every thread. I have an 83 Ranger with a 2.0 engine and 4 speed, 2 wheel drive. I am gathering the parts I need and am not sure which mounting system I should use. I was about to go with the mustang convert mounts, then read where they don't always work. So I got some 1/4 inch plates to fab up with the 4.0 mounts. The question I have is my truck is not here yet and I can't seem to find 2.0 mounts in the auto parts stores to see if they resemble the 4.0 mounts in the way they bolt to the cross member. Any help would be appreciated. I am going 89 Bronco 5.0 with a 157 tooth 50 oz flexplate and a c4
thanks
gt
The 2.0 and 2.3 mounts are the same. You need to get a set of 2.9l mounts from an 86 ranger, which should be a direct bolt in into your engine crossmember...
SVT
