2.0 connecting Rod bolts and head bolts?
gungfudan
Mississippi
3.0 V6
N/A
Total Drop
N/A
I can't seem to find new head bolts and connecting rod bolts for my 88 2.0L.
Can you just use the ones you can get for a 2.3L?
Or maybe some one know where I can get them?
The head bolts from the 2.0 and 2.3 are interchangeable and can be used many times over. Every time I swapped heads I'd scavenge the best looking bolts (black shaft and head with clean threads) and never had a problem with head sealing.
If you have a local yard and need some you can take them from the 2.3...if not then maybe check ebay...
I tried searching but can't confirm the same for the 2.5...one website said they switched to the TTY style but Rock Auto shows them as the older non-TTY style.
