1st Gen Sway Bar Removal
bbbc3
GMRS Radio License
Tulsa, OK
2.8 V6
5"
I've searched through the forum and internet and have not seen mention of the type of sway bar I have on my 1st Gen. It is connected through a cross member.
It looks like I would simply remove all bolts attached to the cross member and the u-bolt that holds the sway bar D shaped bushing. After removal I would ditch the u-bolts and put in regular bolts to hold the lower shock mount. Does that sound correct?
Yep, should be as simple as that.
