1st gen ranger engine swaps
Would a lima handle that amount of boost?
I have no experience with turbo limas personally but based on what wiki says... Stock 84-86 SVO mustangs made up to 240 ft lbs depending on what intercooler&ecu calibration it had.
Getting an additional 60 torques presumably wouldn't be too difficult.
I haven't look into it super hard... if I was to build another I would really look into a TDI.
IMO... if you can't pull it with a 302 a Ranger really doesn't need to be pulling it.
I have a stock crown vic engine with a HO cam, it tows Ranger sized things great.
Which is partially why i suggested a 460 fullsize lol
Detroit 3-71t
Please, let sleeping Detroit 2 strokes lay, and the 53 series were the worst! Ask any old Wonder Bread/Hostess Cake driver- the 3-53 was only 95 gross horsepower and all it made lots of was noise. Drove a 6V-53 in a White Compact box truck 400 miles a night for a while, still have bad memories of that thing. 53 series weren't all that reliable either, after Wonder/Hostess switched to 4B Cummins they were able to lay off a bunch of mechanics.
The 72 series of Detroits though... Best sounding diesels ever engineered.
I have a 3-72 blower sitting around that's just aching to get put on something.. it's either gonna wind up on the ranger or my squarebody.
Dont they have upgraded heads, rods, pistons, etc for that engine? I want all the boost 🥴 i dont mind some lag, can find a hx turbo like hotcakes these days.
You should be able to keep A/C but it might take some work to get a turbo to fit in the right spot making a manifold or something...
I've towed with my '90, it does fine but it takes some R's to do anything. If I remember right the stock tune is supposed to kick in the wastegate at like 10psi, I set my boost fooler thing to stop at about 14psi, the turbo I have now will do more but it gets ping happy without an intercooler. I just did a home port job on a stock turbo head, the dual plug heads flow more apparently. With the same setup and my old turbo after I ported the head I lost 2psi of boost so it's getting more air... The bottom end of a stock turbo engine (only difference turbo or not is the forged pistons) can apparently handle about 350hp before it's an issue and I think crank is the next fuse. The turbo drainback port is the only difference on a turbo block, better off finding some forged pistons and using an N/A block.
Wanted to add sometimes I would have rather done a 4L swap, not having low end is annoying... I had a manual trans '91 Explorer for a while and that thing was great...
As far as other transmissions, you can make anything work with enough money... the most readily available options are T5's and M5OD, I like my M5OD's and haven't had too bad of issues with them.
For what its worth... I really don't enjoy towing with a 5speed.
Can't pull much in fifth out of fear of melting it down... as long as it isn't hunting and you keep it cool a slushbox is much more forgiving.
Pulling our camper down to Kansas and back in mostly fourth running 60-70mph... we moved a lot of fuel. :shok:
Around home, eh who cares. 6-8 hours of it gets kind of tiring.
Another vote for TDI swap here.
I love the Lima engines but they are expensive to build. Parts are getting kind of hard to find. OEM turbo parts are even harder. You can just about build a nice small block V8 from any manufacturer for the same price as having a machine shop go through a 2.3. You'd think it would be half the cost since it's half the cylinders but it's not. Lima's are also pretty heavy as far as 4 cylinder engines go. They make some decent low end power but I wouldn't want to tow much with one - I've owned several, been there done that.
Beyond the TDI, 4.0, 302, and 2.3 swaps, I would just browse CL or Marketplace and see what you can find for wrecked 70's/80's/early 90's anything. A GM 4.3/700R4 maybe, or how about a Jeep 4.0 and AW4 auto? Assuming 2wd here, there has to be a 2wd Cherokee or a junker Astro van somewhere. 2wd opens up a lot of options for RWD cars from the 80's on back too. You don't need much - 200-250HP from a stock V8 is great in a Ranger.
I'm not really on board with the 4BT idea. Heavy and they are kinda popular for swaps so now they're hard to find and expensive.
I like an auto in my tow rig too, having a lower gear available on command without moving the shifter is awful nice. I towed a lot with my old '85 F250 that had a 4 speed, won't go back to that unless I have to.
No idea....if its not a 2.9 im not interested :)
