19lb injectors
jgr1974
Ok thinking of swapping these in. I have had one person reply to another post. He said it made his truck run rich. I am wondering if anyone else has done the swap, and if so a notable difference for the good or bad?
Who ever said that it would run rich is right if you dropped them right in, they must have tried it themselves.. :icon_twisted:
I ran a MAF computer and an IST adjuster to fool the computer to run 19lbs, was a little rich at idle but would bat out when you got on it. I was also running a cam..
The stock injectors will provide more fuel than you could possibly use in your motor. Do some research on how injectors work, then put your money into something that will benefit your truck.
