- - - 1999 Ford Ranger 4.0 V6 Manual 4X2 Lift Questions - - -
Triple R
I have a completely stock 1999 Ford Ranger 4.0 V6 4x2.
I purchased a USED Spring Tech 1998-2000 Ranger V6 6" / 4" Lift Kit which includes:
3" Front Cast Lift Spindle
3" Coils Spring
Upper Control Arms
4" Rear Lift Blocks
Front & Rear Twin Tube Nitro Gas Shocks
However the kit I purchased (USED) only came with the 3" lift spindles & 4" rear lift blocks. I have a few questions that I need answered.
-Do I need the upper control arms and the 3" coil springs?
-Does the 3" coil springs lift it an additional 3" on top of the 3" spindles? Does it = a total of 6" of lift up front or only 3" all together (spindles and coils).
-Can I still crank the Torsion bars for added lift? Is this recommended? If yes, how much lift should I go with when cranking the T-bars?
-Can I run a spring spacer with the stock coil and 3" lift spindle? If so how much of a total lift am I looking at up front?
-As of now I'm told that with the 3" spindles and 4" lift block it has a pre-runner stance (high front / low rear). Can I use shackles to level this out? If so how many inch shackles do I need to level out the truck with 3" spindles only? What size shackles if I ran 3" spindles, coil spring spacers and t-bars cranked?
-What type of shocks do you guys suggest for this lift setup?
-Is this setup ok to run 33x12.50x15?
Ideally I would like to run the spindles, coil spacers, crank t-bars, lift blocks, and shackles on 33X12.50X15. If anyone has any suggestions please let me know! Thank you!
Right on. Didn't know that. Thanks! Well I guess that makes it a bit easier.
