AK Ranger
- May 31, 2024
- Eagle River, AK
- 3.0 V6
- Automatic
Since the sending unit is on your list now, I'm gonna throw out a piece of unsolicited advice... aftermarket is junk... save the old, the pump will probably make it to 200k mi easy. Replace only the part you have to... might not have to replace anything just untangle the float from something etc... OEM is 10x better than aftermarket to repair and rebuid first. (The floats are notorious for getting a pinhole leak, mine did, drilled a hole drained the gas out, soldered it all back up and still working as new 110k mi and 34 years.)
Great advice, thanks for sharing. I’ll take a look sometime soon and report back.
For the heat, the blower motor blows, the heat control switch in the dash feels like it doesn't have much resistance, assuming it is a potentiometer (or similar) that controls a valve.
Also, the upper radiator hose got pretty hot while warming up the truck and lower is pretty cool. I’ll likely start with a coolant system flush and a thermostat replacement.
