- Sep 15, 2025
- Brandon
- State - Country
- MB - CAN
- Other
- Mazda B4000 SE
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Total Lift
- 2 in
- Tire Size
- 32
Manual transmission ticking when in gear and when the gas pedal is pressed, all gears. It's been doing it for over a year (should have checked sooner, my bad, I know). I've drained the fluid and now metal chunks, so from what I can tell it's not internal, it does sometimes have trouble going into lower gears but that seems to be a different thing (synchronizer...?). The transmission had a rebuild and a new clutch shortly after the rebuild. I took over the project from someone else who did the rebuild, I put in the new clutch and throwout bearing when I put the engine in, the ticking has been happening the whole time I've had the truck, thought it was a normal thing until I drove another ranger with the same setup. Any ideas would be appreciated
