1997 4.0 keeps destroying ignition coil cylinder 2/6
wildstang
Forum Member
ORANGE
VT - USA
Vehicle
Drive
stock
stock
235/75 R15
On going problem. This truck has destroyed 3 ignition coils. Middle coil for cylinder 2&6. Blows the interior 25amp fuse. Put a coil on it, seems to run for a short period, then runs rough, drops power then shortly after blows the 25 amp interior fuse. Before I put this last on on I changed plugs and wires. Blew 2 different ignition coils before I changed plugs and wires.
I’m at a loss what is causing the short or resistance. It’s been always the middle coil gets destroyed. I have ohmed them before and after.
For the plug in, the red/light green puts power to it. I’m assuming the yellow/red is coil 3/4 cylinders, yellow/white 2/6 cylinders, yellow/brown (or black) is coil for cylinders 1/5. Where does wire yellow/white go? I’m beginning to think I have a short in that.
Thanks for any help
  • 1997 4.0 keeps destroying ignition coil cylinder 2/6
Also after the first 2 I guess stock or original equipment coils cracked, I bought a Blue Streak. Truck was running good for I’ll guess 50-100 miles then yesterday same missing low power then blew 25 amp fuse. Only this coil didn’t crack and all 3 coil packs ohm just under 12k which is what the were before. I had another original equipment one I put on, replaced fuse. I ohmed it and all 3 were in the 12k range. It started but running rough. Drove it 25 feet into parking spot in front of my garage and quit. Blew fuse and destroyed middle coil.
Actually it may have started to destroy the blue streak one. I just noticed a split in the plastic on the bottom. But like I said still ohms good and no cracks on the top
Check the pins on the trucks connector. If a wire got hot, it could have lost some tension in the female pin in the connector. Maybe cut a pin off one of your bad coils and see how it feels in each pin of the connector.
These guys are saying a failing coil could hurt the ECU and cause a new coil to fail.
Hopefully not I do have a parts 97 b4000 5sp 4x4 and the ecm is very close in numbers.
Do the yellow wires go to the ecm? I want to check the yellow/white wire to see if there’s any issues with it
I feel like the pcm signal wire for the middle coil is grounding out some where
I checked the wires with an ohm meter from the coil plug in to the pcm and they all seemed similar .11 - .06. I checked my 95 and had similar readings,
Maybe the pcm is causing it? I am going to try the coil I bought a few weeks ago in my 95 to make sure it is okay. I did the ohm testing on it and it checked out. The 97 ranger truck did start running rough with that one in it. I may try the pcm I have in a 97 b4000. This one is getting frustrating.
I tried the pcm from the b4000 and no difference. I had a new coil in it at the same time. Started up running rough. Idled less then 5 minutes, blew the 25 amp fuse melt and cracked the bottom plastic on the miss coil again. Middle was hot.
Tonight I plugged both pcm into the 95 and both ran that truck smoothly. I ohmed the wires again from the pcm to coil and they all ohmed around 0.16. I added a ground wire from battery to the ground strap on the firewall that connects to the block. Put another coil in it, no change still running rough.
I pulled the 2/6 plug wires off the coil and it started running similarly rough. Put those back on, pulled 1/5 wires and wouldn’t start. Put those back on pulled 3/4 and started and running similarly rough.
Don’t know
I think I figured that nightmare out. It seems to be the middle coil trigger wire, yellow with white stripe was grounded in the harness somewhere. I cut it and bypassed it and seems to be running fine now.
I had ohmed the wires initially and all had similar values. This afternoon I again unplugged it from the coil and from the pcm. Then ran ground into the coil plug for each yellow wire, hooked test light to the positive post on battery. Probed each wire. When I had the yellow white in a completed circuit it would light up. The yellow/red and yellow/black didn’t light up as expected. But the yellow/white would always trigger the light when it shouldn’t have when testing the other two. That took long enough.
