Kayakfisher
- Jun 10, 2015
- Automatic
Recently got a 97 auto with 150k. Bunch of new parts put in before I bought it including: alt, radiator, front shocks, battery, muffler. Seems like new plugs, or at least wires, as they are red. Still has an exhaust leak after the cat where it connects with the spring bolts. I believe the gasket is shot.
Any way, it idles a bit rough at a stop, and when I accelerate it sputters for a second like it wants to stall, then goes fine.
Things I've checked;
Cleaned throttle body
cleaned IAC
cleaned maf sensor
spray check for vacuum leaks
Unplugged egr
No difference in anything.
Before I go blindly replacing parts and dumping into a hole, anyone have any suggestions on what I should check?
There is no check engine light.
No idea where to go from here. I did some research on forums and the things I've read are what I've done. Thanks
cleaned IAC
cleaned maf sensor
Unplugged egr
