750beater
- Apr 15, 2018
Swap it out if temp gauge climbs when idling, and you don't hear LOUD fan noise on Cold Start
Water pump with worn out impeller(fins) can do same thing, temp climbs at idle, but you would still have the loud noise from working fan clutch![]()
Oh and I replaced the water pump a couple thousand miles ago. It basically had no teeth, which I figured explained the odd temp readings.
