- Nov 18, 2011
- Automatic
- Tire Size
- 235/75/15
- My credo
- Do what you can, Where you are, With what you have-Eleanor Roosevelt
First off, I searched the forum for the answers, but could not find what I'm looking for. This is a long read, so I want to thank you ahead of time for reading it and hopefully giving me your input.
Here's what I have: I picked up a 1996 Ranger XLT 2wd, 2.3L with a 5 speed. The guy who had it, drove it into the ground! It was one step away from the junkyard.
Here's what I've done so far: I replaced the engine with a 2.5. I replaced the timing belt, tensioner, water pump, thermostat, spark plugs, wires and an assortment of sensors. I also installed a drop in K&N filter. I replaced the power steering pump, the lines, the sensor and added a cooler. I replaced the radiator, cap, heater control valve and all the hoses. I replaced the clutch and the slave cylinder. I replaced all of the shocks and added a steering stabilizer. I replaced the wheels with some American Racing 15x8 rims with some 235/75/15 tires. Later I found out that I needed to change the gears, so I pulled the 7.5 and installed an 8.8 with 4.10 gears and a limited slip. I replaced all of the brakes and upgraded the rears from 9 inch to 10 inch. I installed a rear sway bar. I replaced the bushing in the front end. The exhaust was in bad shape, so I replaced everything except the header. I installed a Magnaflow cat with 2 new O2 sensors and a Dynomax exhaust system. I even painted the exhaust with some high temp paint. The paint is still holding. I changed the fleetside bed to a flairside (stepside) bed. I also replaced the filler hose. I installed a trailer hitch and a fiberglass tonneau cover. I replaced the stock headlights, turnsignals and tail lights with some aftermarked ones. The interior was in bad shape. I replaced the bench seat with buckets and a center console out of an Explorer. I hand stitched a leather wrap on the steering wheel. I added a vacuume and volt gauge in a pillar mount. I even added one of those loud air horns.
I still have a few things left to do and that's where I need some help. The truck runs really good. The gears and the tires work well together. The ride is tight, but not harsh. Prior to this Ranger, I had an 02 Ranger Edge 2wd. I really liked the ride hight of the Edge, but at this point I can't sell the '96 to go find one. I was thinking about adding a 2 inch lift kit. This is my daily driver, so I don't want to have a real stiff, spine snapping ride. My front end looks a little off, so I have to get that adjusted anyway. This truck will not see any off roading. I might pull a jetski on the beach, but that's about it. I was thinking about adding the two inch lift blocks from a 4wd Ranger for the rear and some F-150 coil spacers for the front.
Here's my questions: what will it do to my ride quality? Will I have to get longer brake lines? Can I still use my sway bars? Will I have to extend them? Will I have to change out the shocks? I looked at the specs on the shocks and here's what I found: The 2wd fronts extend to 14.5 inches and collapse to 9.75, while the 4wd extend to 15.5 inches and collapse to 10 inches. Those are pretty close. The 2wd rears extend to 23 inches and collapse to 14.375 and the 4wd extend to 26 inches and collapse to 16. It's a little bit more noticable in the rear, but I'm not going off roading with it. This past summer, we had some deep flooding in my neighborhood and I would like my Ranger a little higher out of the water when I'm trying to get through it. And the final question: Would it even be worth all the effort?
