- Feb 15, 2020
- Southern maine
- State - Country
- ME - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Manual
- Total Drop
- Shackle flip
- Tire Size
- 235/60/15
- My credo
- Its probably better to be self deprecating than self defecating.
If there is no coolant where the sender is, it doesn't know the temperature and goes off of the metal temperature it is screwed into which depending on the location usually isn't where the heat is made so will read cool...
The gauge is pretty much reading the continuity to ground, when cold there's little continuity so doesn't have much to push the gauge up, as they heat up the resistance goes down and drives the gauge higher (however that side work). If it's a one wire sender it is using the threads as a ground reference, if two pin one is ground and the other the signal... if one wire you can check the function of the gauge by simply grounding the wire.
A 4x2 4 cylinder should be cake especially regular cab so it's one piece rear driveline, 6 bellhousing bolts, 4ish bolts for the transmission crossmember, 4 driveline bolts, one connector and one quick connect for the clutch hydraulics, I've done that in a day before... On a V6 the exhaust is always in the way of getting the trans out...
Yeah.. exhaust gets nasty up here too lol. I'm betting that's where a good portion of his labor came from, I'll try and stop by the shop for an estimate tomorrow. That centerforce combo is definitely what I'll be going with.. looks like 275 plus whatever a new throw out bearing is.. not bad.
