2.3L ('83-'97) 1995 tfi?
901wd#2
Vermont
Mocking up an m90 on an 89-92 lower intake, the tfi module is a bit in the way, i’ve got two 1995 2.3 engines here and I can’t find a TFi module on either one of them, admitting my ignorance. What am I missing?
In '95 that moved into the ECM when they changed the crank sensor.
You can move the module, just mount it to a big aluminum plate to dissipate the heat, only use the 3 holes it was originally mounted with (I know it has 4) and make sure that plate is grounded... I've been running mine like that for years...
